Tin Falcon
- Jul 9, 2007
- 7,207
- 789
After reading the rant on the poor quality of a 115 pc drill bit set I got to thinking.
before I express those thoughts
I want to say this all respectful thoughtful input welcome.
I will not let this turn into another all Chinese tools are crap thread
or a American manufacturing is going down the tubes thread.
I have heard the complaints and the gripes and some are valid some use such threads to vent the same old stuff. I am looking for solutions to problems and a way to make the home shop productive and not pay top dollar for tooling .
I am not tying to solve a debate here if you can afford to pay full retail for new american made tooling god bless you if you only can afford the import stuff that is fine as well.
And i will remind you this is from the perspective of a home shop.
One of the points brought up in the other thread was getting new drill bits with less than a perfect grind. OK if you look at a machining manual or the machinery handbook you will see that different materials work best if the drill is ground for that material. Industry standard is pretty much 118 degrees for common use and a 135 degree for harder material and better performance. Brass and cast iron works best with zero rake at the edge .4/6 flute sharpeners are becoming more popular.
http://www.gadgetbuilder.com/DrillSharp.html
Info on the web is available. there was build article in home shop machinist and Tormek sells a very nice jig for drill sharpening. And of course there is the drill doctor. So IMHO there are many good reasons to have the tooling knowledge and experience to sharpen a drill bit in the home shop.
The first reason that comes to mind is better performance. Tools dull and drilling is likely the number one machining operation so you need to keep the edge. Then economy most HSM folks are more concerned about money than time so it makes sense to sharpen drill bits and get you moneys worth.
IF I pay 2-4 hundred dollars for a USA made drill bit set yes I want the cutting edge to be ground right. But if I pay say $ 50 for a HF set and some of the edges need work or the symmetry is off is that really a big deal ?
Like i said earlier sometimes you want a grind that is not factory standard.
If I purchased 100 lathe tool blanks for $50 I would expect to have to grind every one to my own specification and grind it to purpose. Is it that much different buying 115 drill bits for the same money and having to grind a few to make the do what I want?
This hobby is about creativity, understanding tools, geometry, metals etc. sometimes it is a matter of adapting to overcome even when it comes to a humble drill bit.
When I worked in the pro shop running CNC the first thing we would do when a new carbide boring bare came out of the pack was grind it the way we knew it would work best.
I am an advocate of getting the best you can afford and the best bang for the buck in the long run . We all have to choose our own tooling.
It should not be a big deal to sharpen a drill bit . And a $150 is a good bit of money to save.
I know many of you out there know what works best for you and have a strong opinion and that is fine . This is fa few thoughts for the open minded who love to machine but are on a budget.
TIn
TIn
