T70MkIII said:Chuck, just backtracking a few posts and a slight thread drift - do you usually run your mini lathe without the gear cover on, and why the handle on the leadscrew? I see you've taken the chuck guard off too - very annoying piece of kit, and I'm thinking of doing the same (wearing safety glasses, of course).
Great looking radial so far!
1hand said:Chuck,
I really like how it flows together, from the crankcase into the cyls.
Nice work!
Matt
compspecial said:Chuck, you are an inspiration, this engine has an elegance like the old Anzanis. I must confess I was absorbed by the pictures and assumed it was going to run on air, but when I read the text more carefully and found its a four stroke WOW its gonna sound great. hope you can find room for the valves in those heads
vascon2196 said:Great looking engine Chuck...looking forward to seeing it in action!
Chris
rleete said:Holes in the front, or even a clear cover is recommended. Gotta see the moving bits to make it more interesting! Why go to the work to shape your "master crank thingie" ( <-- technical term) if you're just going to hide it inside?
Hint: use cut up soda/beer cans to protect those cylinders when chucking in the lathe. Much less work than polishing out the jaw marks afterwards. Plain old masking tape works, but limits holding power a little.
