Bentwings
thanks for the tip. When searching for these I saw different numbers so I assumed it was the depth theyvwerevtonbebinstalled at . I’ve just made sure I tapped deep enough that the part was in full depth according to its size . I surely can see that tapping too shallow will cause problems or as you noted the depth of tapping the set of inserts I have are all about he same ratio of diameter to length so you tap for hemTimo, I like the picture of the double-ended stud in your post. When the threads look good under magnification, with no tearing or irregular crests, it is a satisfying sight.
One thing I forgot to mention about helicoils is that it is very important to tap the hole deep enough with the special helicoil tap. If not, the helicoil will taper in at the bottom and the bolt will lock up in it and then you have a mess on top of a mess.
Edit: And I also forgot to mention that the special spring loaded tool (like a spring center punch) for breaking off the helicoil insertion tang after it is installed, is called a tang-banger.
Yup, that's the proper technical name.![]()
Byron
