I have a stack of hard drive disks here, with thoughts about a Tesla turbine in mind for the distant future. They look like chrome plated, but I suppose the finish must be a magnetic oxide, and who knows what underneath. OK if air is your driving medium. The bearings aren't really accessible being built into a central motor/bearing units. There are a couple of wicked magnets in each drive too.
One things about the Teslas is they tend to spin very fast which can be a test for the materials and bearings, and I assume is a function of the inlet air flow, which will be limited by the speed of sound if the pressure is above about 25psi. By my calculations this would mean 70,000rpm for a 3.5" turbine, which could burst it. Certainly I have heard concerns about overspeed if the load comes off suddenly. I was wondering if you could use an induced air bleed to (sort of venturi effect) at the inlet to bulk up the air flow but slow the speed, so that you get rid of the overspeed potential. You would still have the same air momentum, but shared with a larger air volume, so I would think you could get as much work out of it. Maybe someone here can tell me if it is a daft idea..
Steve
