colin said:
Hi guys I have an awful lot of blind nuts to make any suggestions or home made tooling to help with the tapping of them to speed things up.
Colin,
I assume that by "blind nuts," you mean a blind tapped hole for something like unto an acorn nut. ??? You might want to think about
forming the threads rather than cutting them if the material is malleable enough. This process is quite dependent on the lubricant used, but most suppliers of such taps produce guides to lubricants.
An adjustable torque slip clutch makes life a whole lot easier when using this type of tap ("TorqueTamer" was the brand of such clutches most common in my area -- Washington State -- a few years back). That way, when you bottom out, the tap merely spins in the toolholder (you will have to make your own adapter). A real tapping head is even better. Beware of the Chinese imitation "TapMatic" heads. Some are OK, but many have a ways to go before they qualify as marginal. There is an Indian-made tapping head (sold by Harbor Freight from time to time) that is actually pretty good. The main thing with the Indian unit is to take it apart, clean out the debris they leave in it, grease it up with good lithium grease, and watch all the adjustment screws (ND brand "VibraTite" works quite well) as they tend to loosen up with use. Once reworked in this manner, they are about 80% as good as a TapMatic head. (I usually replace the "Belleville washers" in them with good quality ones too.) A tapping head provides axial misalignment compensation that you will
not get with an otherwise axially rigid set-up with an adjustable slip clutch.
Figure a TapMatic head will run you about $500. The Indian head from Harbor Freight is usually priced about $100. A 40 lb-ft rated TorqueTamer (nearly a decade ago) ran about $50.
My paper on
Pilot Hole Considerations posted at
http://www.scribd.com/Lew Merrick has the equations for calculating the proper fit for form thread taps. The pilot hole is
larger than you would use for a cut-thread (standard) tap as you are
moving material to make the threads rather than cutting it away.
