putputman
Senior Member
- Nov 22, 2008
- 600
- 55
This might be a good project for those who are just starting in the trade or hobby. My mentor had me make this tapping tool over 45 years ago and I still use it very often. It is a tapping tool that can be used in the mill or lathe.
Most taps are broken by bending rather than torque. This tool supports the tap so it can't be bent. I am not saying I haven't broken taps, but I can count on one hand the number of taps I have broken when using this tool. Most of the taps I have broken are done with a t-handle tapping tool.
The 1/4 inch dowel pin is chucked in the mill or lathe and the tapping tool is a slip fit on the tap inserts. On the mill you turn the tap in by hand. In the lathe you can turn the tap by hand or use power & hold the tapping tool from turning. Either way, you have a lot of feel for the torque. On real small taps I remove the handle & hold the knurled knob.
The tool consists of a hand or knob and 4 inserts. The inserts are held in place with a single set screw.
The smallest insert covers taps from 0-80 to 6-32 in both standard & fine threads. The other 3 are for 8-32, 10-32, & 1/4-20 & their equivalents in coarse threads.
I will put some prints in the download section for anyone that might be interested in making this tool.
