Posted while dodging bits and pieces of Sam's head.....LOL
Still taking it easy, but I did manage a little time on the mill.... for which I duly paid the toll. I'm ready to begin establishing the elevation for the crank and flywheel which will soon need to be made and fitted. The project for the day became making the first of two stands that support the cylinders. As the photo below shows, things began with a bit of layout work. The design was scribed into the brass as a guide, although some adjustment would naturally occur during machining, as needed to please the eye.
http://cedesign.net/steam/images/misc/multi-valve/build/stand-1.jpg
The first step was to drill a couple of pivot points. The marks were center drilled after the wiggler was used to locate them.
http://cedesign.net/steam/images/misc/multi-valve/build/stand-2.jpg
This piece does not have but a couple of critical dimensions, height and the radius that will support the cylinder, The other radii were cut using an end mill and were simply aligned according to the marks. This allowed me to sneak up on the lines before milling the holes. These holes serve a dual function by creating a nice curve at various places on the part while giving me escape points for the straight cuts.
Here you see the web being milled, using a small 1/16 ball end mill. This is where the visual adjustment came into play. The original layout was for 1/16 flanges, but this proved to look a little clunky so they quickly became 1/32 wide.
The small table in the photo is a modification of the Rounding Table Marv Klotz introduced to the forum in days gone by. Mine has a round top making it perfect for not only rounding ends and cutting arcs, but for things like these web cuts on angles. The stops make it easy to align the cut and hold in in place.
http://cedesign.net/steam/images/misc/multi-valve/build/stand-3.jpg
Here is the "finished" stand, needing only a little more tool mark removal and a couple of holes to secure it to the collar of the cylinder assembly. The flat base and The edges of the flanges were rounded a bit and the feet were blended into the base.
http://cedesign.net/steam/images/misc/multi-valve/build/stand-4.jpg
Amazingly, the cylinder assembly is almost perfectly balanced and will sit atop the stand with no assistance. I'll still need to add a second support under the cross head guide to compete this phase. I'm quickly running out of things to do that don't require working on the machines, so lets hope some significant healing begins real soon.
http://cedesign.net/steam/images/misc/multi-valve/build/stand-5.jpg
Steve
