stevehuckss396 said:I have an old 1.8 gig CPU and XP.
This is right off the mach site.
Mach3 Minimum Requirements:
◦32-bit version of Windows 2000, Windows XP, Windows Vista, or Windows 7 Operating System
◦1Ghz CPU
◦512MB RAM
◦Non-integrated Video Card with 32MB RAM
◦Basic Computer Skills (ability to copy/rename files, browse directories, etc)
◦Desktop PC (if using the Mach3 Parallel Port Driver - laptops are not supported because the power saving features of the chipsets disrupt the pulse stream, PCMCIA and USB parallel adaptors will *not* work.)
Tin Falcon said:You guys are making me feel gheto for using the same power supply and g540 for the lathe and the mill .
I have purchased L-com products from Allied . Seems like nice stuff Looks like something else to add to my things to oder list.
bob Warfield built one from a harbor freight pheumatic wrench. IIRc it cost about $100 in materials. you do need a compressor to run it.Save the bucks from the seperate drive and computer and put it in to a power drawbar. Boy that would be the cats meow for one handed tool changes. Grin
Tin Falcon said:and a few db 9 cables
Sure thing. You'll have to add a resistor between two pins on each cable at the gecko end... or inside the switchbox... hmmm...1hand said:Can I use pre made cables?
Tin Falcon said:bob Warfield built one from a harbor freight pheumatic wrench. IIRc it cost about $100 in materials. you do need a compressor to run it.
