Looks great. Your in up to your a$$ now!!
Matt;mnewsholme said:Im working from basically the same set of plans but for an x3. just wait till you see the hunk of aluminium you need for the x axis motor mount ;D
matt
1hand said:Thanks Tin;
I need a bit of explanation here. Do I then make a mounting block with the 15/16-16 thread in one end, and then screw that square style ball nut into the mounting block? If so, what holds the ball nut from unthreading when the ball screw is going in that direction? Set screws in from the side?
Thanks Matt
1hand said:I only have a lap top, and was wondering what sort of computer I need for the CNC to run Mach, CAM, and a Gecko drive? I thought I read some where that a laptop won't work. I know little to none about computers also
1hand said:Matt;
What are you going to use for X and Y axis steppers? 23's or 34's?
Matt
Tin Falcon said:Also keep in mind there is a amperage limit (3.5 amps/phase)on the gecko drive make sure your beefy z axis motor does not exceed that limit it may be better to use pulleys and a smaller motor.
1hand said:I've been doing some searching on limit switches and Homing switches, and have opened a whole other can of worms. Are they needed or can you use the soft limits in Mach 3 and still be safe?
Matt
1hand said:So what your saying is, I don't "have" to have them to run the machine with Mach 3, and If I'm careful, I shouldn't need them.
any now end new or decent used machine should do the job the requirements are fairly conservative by today's standards . Look at Mach 3 site for requirements.Maybe it would just be easier to use a different drive or drivers and stick with the 34's all the way around. A parallel port is a printing port right? So your basic $200 desk top computer would run this right?
