homemachinist
Active Member
Hello all,
I'm fairly new to machining and am in the process of converting my lathe (Optimum TU2506 clone) to CNC. I notice banding at regular intervals (seems to match the Z leadscrew pitch of 3mm) as if the tool is being pushed towards the stock but only when both X and Z axis are in motion at the same time (like turning tapers). Simple turning operations where Z and X are moved separately but not at the same time comes out perfectly fine as seen in the picture.
I initially suspected a bent leadscrew but if that's the case expect the banding artefacts to appear in the straight turning operations as well. I've tightened the saddle gibs at the back (there's none at the front).
Any thoughts or suggestions ?
Thanks
Thanks
