nesikachad
- Oct 12, 2010
- 18
- 0
Grab a big syringe. Collapse the plunger. Now plug the opening and pull the plunger back to generate a vacuum. There is resistance. (As one would expect right?) Now allow air back into the cylinder. Plug it off again and attempt to collapse the plunger once more.
I think you'll find that it takes far more effort to compress the air than it does to overcome a vacuum. Lesser of two evils. . .
Have remember also that gasses will piddle past the rings which will only compound the matter. Simply venting to atmosphere won't do once you start turning higher rpm.
