Fault timing of the triple expansion steam engine..
You must connect the air pressure to the cylinder and adjust the timing and test running in H.P, then I.P cylinder and last L.P cylinder.
To running test for each cylinder: Remove the two connecting rod to other cylinder who is not in use (due less load caused by friction), the cylinder who is under test/adjusting timing must have connecting rod to run the steam engine. Also you are adjusting/running the triple steam engine as if it were "one cylinder steam engine".
After each cylinder has correct timing and running test for each cylinder is done, mount all connecting rod and the two manifolds on place and the triple steam engine is ready to run.
Here is my triple expansion steam engine running on air pressure under test.
[ame="https://www.youtube.com/watch?v=1xhXqMLKHeQ"]https://www.youtube.com/watch?v=1xhXqMLKHeQ[/ame]
