Thank you all for your kind comments! I must admit that posting a build really helps to finish it. Normally I am very good in starting projects, not so good at completely finish them. The interest shown by you all almost obligates to show the end result, which is a good thing! I hope next weekend I will have all parts finished and assembled. Why the delay......a new project has arrived..... :
I got myself a Harrison trainer 280 lathe yesterday. Its a very nice and stable lathe but the best part is that you can use it manual as well as CNC. For what I can see up to now the disadvantage is the spindle speed selection, its with 2 rotating wheels. Not very quick to change a gear, on my Emco there are 2 handles (levers) making a gear change a matter of seconds. However, a frequency inverter on the Harrison will mask the gear selection problem....
The machine is 19 years old and comes from a technical school. Below the grease and dirt its practically a new machine, the paint on the inside (where the swarf ends) is not even scratched! Probably just used for aluminum and plastics. Even though its in a good condition I will take the machine apart and clean, check all parts and the reassemble it. I like to know what I have in my garage
When the machine is mechanically ok and checked I will convert it so it will run under Mach3. I do not like to put my money on 19 years old electronics, every day more they work you are lucky!
The top slide is ready for remount:
And some work on part of the body panels (they where dented), they are ready to receive the ground layer of paint:
I will do my best to not work on the machine, and get the Stuart finished...... :-\
Regards Jeroen
