- May 30, 2011
- 135
- 4
I have bought very little in materials so far, so i do not have much experience in the raw dimensions of material.
I've bought 1" and 2" diameter Aluminum round, and when i brought it home my caliper said they were 0.06" oversize. This is good so as we have some leeway to get a good finishing surface if we wanted exact 2.000" diameter. Is this true for Hex bar?
Looking at crueby's 6 Cylinder Radial engine plans it calls for 2" diameter (measured from the flats) Hex shape, and since buying a piece of 2" hex doesnt have a precision surfaces, is there extra material to to mill off the surface clean. (use of hex bar would promote less waste than using round stock and turning
Also, for flat bar stock or plate, is that over sized as well?
With lumber it's the opposite; the physical dimension is smaller than advertised: a 2x4 is really just 1.5"x3.5" due to the wood shrinking.
Thanks,
Ian
Thanks,
Ian
