Daryl: I suggest the bottom plate (that "sees" the heat source) should be BLACK, or Matt finish, to readily accept the radiant heat from the heat source. (Shiny silver rejects 95% of the radiant heat!).
The Top plate, which is the cool end of the Displacer, should be black as well, but probably insignificant compared to the surface cooling that occurs.
I "hear comments about end plates "as thin as possible", but the difference of conductivity of a 0.6mm plate compared to a 1mm plate of whatever metal is barely worth considering, in terms of heat flow. I doubt if you could measure even a 1 degree difference in surface temperature on a 3mm thick steel sheet in this application....
But a black coating on the bottom of the displacer chamber (that sits on the boiler top) is REALLY worthwhile.
To check it out:
Hold your hand a few inches from the boiler top. Feel the RADIANT heat.
Use a sheet of aluminium foil to make your skin Shiny, I.E. Touch the foil, (stick to your hand with some glue?) and hold it in the same place, and it will not be so hot.
You will then "feel" the difference of a shiny surface compared to another non-shiny colour (skin).
Welders often use a shiny foil thimble on their welders' gloves to reflect the radiant heat away from their digits.
To check it out:
