Here is my first stirling engine intended to be a wood burning stove fan. My issue is that it takes too much heat to get running. Can anyone suggest where to start redesigning to lower the start up temperature? The lower inch of the dispacer cylinder is aluminium. The displacer is a plain hollow stainless steel cylinder with closed ends. The ratio between pistons is around 3.75.
