It's a twingle I started to work on cam to crank timing after I made the flywheel and engine stand so I could roll the engine over so I focused on one cylinder piston going down intake open piston up fire then exhaust normal cycle then looked at other cylinder and it's almost right on the same combustion cycle! What this can't be right-----or can it after researching on the Internet for a while I found it will work it's called a Big Bang or twingle instead of the normal 315-405 firing interval it fires at 45-675. So both cylinders fire the at the same time or pretty close to the same time. I never worked on V twins so all this is new to me. So Hera are more pictures of mock up. Oil pump installed
Starter/ generator
Flywheel complete it was fun rolling the bar for the rim
Pushrod tubes and push rods
Distributor
Die for making head gaskets
The engine rolls over so smoothly with so little effort (no rings on Pistons) I can't say it enough what an amazing set of plans Jack Draw-Tech has created. Back to the shop need to get some fuel & fire going, see if I can get it to backfire or run. Still lots of small parts to make! Happy New Year to all.
Steve
Starter/ generator
Distributor
Steve
