Bogstandard said:Very nicely done Chuck, and a very good result. It looks like you had a lot less trouble than I did.
I gather you like the smooth action and easy adjustment over the old method.
I have to agree with you on how easily it can be done, I reckoned on a good day or maybe two in the shop if everything with the machine was OK.
BTW, great fix on the adjusting screws, I had a crap time trying to make the slots strong enough for adjustment, your method completely solves that.
But if anyone is going to try this, give it a good measure up and check for squareness before you start to hack away. You must watch out for things that are out of line or bent if you have an older type of machine.
Some of those early ones were made by cavemen with flint tools.
Bogs
Twmaster said:Some of those early ones were made by cavemen with flint tools.
The ones as of 2008 were as well in some instances...
Chuck, after looking over your gibs again I have to say that hands down this is way better than the route I took with shimming my old 7x10 lathe. I cannot see this taking any more time than I spent fussing with making shims.
Between your posts and Bog's thread over on MM I think anybody with a mill can make these.
One last silly question. (The tool geek in me wants to know) what milling machine do you have?
Thanks!
zeeprogrammer said:I'll take 2.
First time..."Drat...I knew that was going to happen."
Second time..."Drat...Not going to let that happen again."
No one should admit to more than that. ;D
Swarf Rat said:Chuck, I really like those big-headed gib adjustment screws. I wonder if they'll need some kind of lock to keep them from vibrating out of position.
Cool idea to shim the apron to fix the pinion clearance. Does that not affect the half-nut allignment or pinion engagement?
ozzie46 said:Cfelloows, How will the shim effect the mesh of the rack and the saddle gears? It seems to me you have introduced .010 free play between the gears. Maybe it won't effect anything.
Ron
