I can try to get a pichurgraph for you tomorrow Bill, but in essence, all it is is a couple of inches of 3/4" square steel, with a 6BA clearance hole drilled through, then opened out to fit the round bit on the knuckle pieces - I went about a 1/4" deep, although the round sections were only a bit of 1/8".
The procedure - insert workpiece in hole, square up with a small square held against the side of the block. Put a 6BA bolt and washer in from the back and tighten well down. Now bung the lot in the vise and get it standing truly vertical, set the slitting saw to height, and away you go!
