D&J Fitzgerald
Active Member
hi outthere, first i thank you kindly for members help , i am new never built a steam anything, the closest i have come to building a steam engine is in watching other peoples progress in youtube. I have never run a lathe in my life, my only experience is in model ship building, and in having decades of scratch building ships off of plans, has helped me in some very very light understanding in viewing steam engine plans, i see i have a long way to go, i do not have a degree in engineering at all of any kind but the will to conquer metal is at hand. i have a cheap chinese metal lathe 7×14 550 watt motor i am making progress and reading everyday all i can. i have several plan sets downloaded into my phone my faverate is a condencing engine
with Lp and Hp cylinders it is big 3 inch bore on one and a 2 1/4 inch bore on the other its 8 inches long, 7 inches tall and i think 5 inches wide a bit big for my 8 ft tug, i am going to follow the advice of the members and attempt a small single vertical with 1 1/4 inch bore. but i have a problem it requires castings, i would make the molds for the bed, and cylinder ,steam Chest and standard and i have the dimentions the standard is 4 inches tall showing two sides of its four faces one with the legs and dimentions the other side with the rectangle hole at the top of the standard but i am trying to figure out how i apply those two dimentional drawings of the standard to the the mold. i cannot find a book that covers completely on how to apply the drawing and dimentions to a wood plug , i will assume that the mold has to milled on my lathe slightly over size to leave material for machining. its just the standard. another sort of question is this does the Standard, Cylinder, Flywheel and base molds have to split in half for the mold box and the mold box split into two as the case with the molds for the parts ? can someone confirm these things please. and maybe this is stupid question but, i asume i have to mill the molds to dimentions indicated plus extra for milling on my lathe correct?
plus mentioning the size of the first engine thatbi wish to build as i get more experience is my 7 by 14 big enough to build that engine maybe not. i am ordering the ray hasbrook book soon.
the vertical steam engjne will be my first go, i have decided this, i got the plans from i think Tom.com the plans are easy to understand and the dimentions its just the plans, to mold, to castings problem. could I machine the standard out of wood and omit the legs to make it simpler and add the wooden legs later? again must all the molds be in two parts for the casting sand boxes. please kindly someone answer these issues.
thanks very kindly Dan.
