The latest MSC flyer has a couple of real good deals this time.
The first is on page 10, solid carbide spot drills. It is really worth getting a couple of each angle of the smaller sizes at these prices (or bigger ones if you can afford them).
The next is on page 12. These are 60 degree radius type centre drills. You use these when taper turning by using the tailstock offset method, the curved shape allows your tailstock centre to sit correctly, which it can't do it you use a straight sided angle on your centre drill. Worth picking up a couple for when you do get around to doing some taper turning.
http://www.mscjlindustrial.co.uk/CGI/INPDFF?PMCTLG=20
VAT & postage will have to be added to the prices. But at least you get next day delivery.
