Cedge
- Jul 12, 2007
- 1,727
- 28
I'm probably not alone in having built at least one "Ball Cutter" for my lathe. Truth being told, Ive made several in the past couple of years and each one gave me ideas of what I wanted in the "perfect version". Below, you'll see my latest iteration of this fun tool. This one is unique, although it is solidly based in designs shared by John Moran's and Steve Bedair's web sites. Both of these guys have been inspirational in my efforts to learn a bit about machining.
The swivel idea is abviously borrowed and somewhat modified, but there is where the similarity ends.
The one shown below has several features I've added for my own convenience and fun.
First of, the cutting head is interchangeable so I can swap cutters when the material demands it. The second item is the tangential cutter or "diamond cutter" . This basic idea was also borrowed from John's list of tools and modifications. I simply changed the design a bit and adapted it to the ball cutter. If you've never used a tangential cutter, you have no idea what you are missing.
I wanted the tool to be easily adjustable without having to take it apart so I added a small 8x32 tpi lead screw and carriage to make adjustment a snap. This little mechanism also holds the tool intact when things are lossened for movement. The short version is I finally have the tool I want with the features I'd been wanting and its one sweet cutting little gadget.
The second version is in the works which will cut concave contours with the same ease of control. I tried the dual use approach on earlier tools and decided I could live with two tools, if the accuracy and user friendliness of both was improved.
Okay...I know... It's not a steam engine, but its one of the items here to help me build them....LOL. In fact it's the exact tool I need to put the finishing touch on an engine that is way long overdue for its first test run.
Steve
Steve
