flatbelter said:Yea, about them tiny electric boxes... I just killed at least one pick up, maybe two (hall sensors) by flooding out the engine. Seems flooding the gap on the plug will feed back enough voltage to toast the sensor. (airplane engine mounted upside down.) I don't have that trouble with the stock magneto...
Kind of disappointing end for the day as this is the heavily modified 26cc weed wacker engine that I've been playing with for the past month.(Wanted to start it today with the new ignition) Looks like I will have to go salvage the hall sensors off an old computer drive then flip the engine spark plug up so it doesn't flood the plug again.
Good luck with your salvage quest.
FB
You tryiing to use one of those cheap Hobby King electronic ignition units? I've been giving them a look over and wondering if they'd be worth experimenting with. They are surly cheap enough.flatbelter said:Thanks Jim,
Digikey is a good source for electronic parts and they ship fast too.
I only burned one sensor, the second one is still working so far. However the engine has some other issues that need to be fixed before I can try starting again. (prop adapter problems)
This is my third run at converting a weedwacker engine to airplane use and the most ambitious. Only the piston and rod assembly remain stock. It is however the first time trying to use the "magic box" electronic ignition. Hopefully I'll get it all squared away soon.
jpeter said:You trying to use one of those cheap Hobby King electronic ignition units? I've been giving them a look over and wondering if they'd be worth experimenting with. They are surly cheap enough.
