Hi Arnold
Ive never made a hit n miss before, but its my best guess that u set it to run as well as it can and then change the strength of the governor springs to give more or less miss.
eg weak spring will miss lots and a heavy spring may not miss much or at all. (as is the case here) But all the same, if the spring is too weak then I would think the valve would not work and the engine not run.
you may notice, that to get it running the first time I took out the lockout lever and only put it back once the engine was running well.
I would imagine, u would want the engine to run as fast as possable( considering there is no throttle on a hit n miss ) so that once the exhaust valve closes again after a miss, the engine still turns over and Hits again.
At the moment I'm using heavy springs taken from an old printer,but will have to find or make lighter ones to make it miss more.
I went into some detail here in the hope that u do build the Kerzel, cos I recon with a few minor changes, its a great little motor. 8)
all the best
Pete
