Superfast
- Aug 25, 2008
- 19
- 0
I started this engine about 3 months ago and got side tracked until last week. I just finished it up (atleast the first part of the project) about a week ago. It is a smaller version of Chuck's Famous Single engine. This one is a 2 cycle version, as I didn't have any small gears to make it a 4 cycle. The flywheels measure 2" diameter, it has a .500 stroke with a .600 bore. The valve came out pretty small, the 4 screws holding it together are 0-80 cap screws. Instead of using a standard cam, I used a 0-08 cap screw to operate the valve linkage.
<a href="http://www.scottsrc.com/machining/horizontal1.jpg"><img src="http://www.scottsrc.com/machining/thumbs/horizontal1.jpg"></a>
<a href="http://www.scottsrc.com/machining/horizontal2.jpg"><img src="http://www.scottsrc.com/machining/thumbs/horizontal2.jpg"></a>
<a href="http://www.scottsrc.com/machining/horizontal3.jpg"><img src="http://www.scottsrc.com/machining/thumbs/horizontal3.jpg"></a>
<a href="http://www.scottsrc.com/machining/horizontal4.jpg"><img src="http://www.scottsrc.com/machining/thumbs/horizontal4.jpg"></a>
It still needs alot of cleaning and polishing, but seems to run decent, Here is a video:
[ame]http://www.youtube.com/watch?v=95T4c9B7Xu4[/ame]
As you can see in the video the left hand side of the crank is a little off and causes a slight wobble in the flywheel. This will be fixed during the next part of the project. I am going to try and add a flyweight governor to it and make it run like a hit or miss engine. So far I have built a new crank, 2 new flywheels and have a trial assembly of the governor.
Scott
Scott
