ok my daughter has done all the computer stuff the digital readout on my little lathe is enough for me i am just learning how to text we will see how we go with this the firing order of this little engine is 12478356 number one is left hand side front number two is right hand side front so 1357 on the left and 2468 on the right . notice full stop. im learning. the firing order could have been a few different ways including 12345678 but i thought i had better spread it around as much as i could. the bore is 1.250 and the stroke is 1.187 .the stroke ended up that size because that was as close to the bore size i could get by putting the jaws in the three jaw in the wrong order . because i had to copy these sizes numerous times. the crank has ball bearing mains 15 mm id x 5 and big ends are needle rollers 12 mm id 90 degrees apart starting from front of crank , not like a couple of other throws that i have seen ... but this isnt where it all began, maybe this can be chapter one ...time here is 7.30 pm aest
aust time
