Hello all, while attending the 1000 engine rally here in the UK I came across these castings for a small gas engine. The large parts had been machined and a few items were included with the castings. It is always a risk buying castings that have been machined as to whether they are correct or not, luckily these measure up fine to the drawings.
The engine is not a model but a full size engine. The bore is 61mm and the stroke is 80mm. The flywheel is around 14" in diameter and 2" across the face.
Although it is not a model, It is a Klein gas motor of German manufacture, I thought some of you would like to follow my trials and tribulations in a build log for it.
I will be ran on propane and have hot tube ignition, it has sideshaft driven cams that operate the valves. I may also fit a CDI ignition unit and spark plug so that the engine can be run outside if it is windy.
Let me know if you think a build log would be of use to anyone.
A few pics of the castings below, the vernier in front of them is 6" and should give some idea of the physical size of the engine.
MartinH
MartinH
