- Sep 19, 2015
- 274
- 80
Hi All
I have slitting saw job coming up in aluminum . The slitting saw is 63mm which is about 2.5" and 3mm about 1/8" wide and 38 teeth, straight hss blade which gives me the shivers just looking at it. I have looked up Little Machine Shops feeds and speed calculator and treated the saw as a big mill cutter which gave RPM speed of 310 and a chip load of 0.42mm . Feed rate is at nearly 5m or 194 ip per minute which I couldn't crank that fast if I tried..The slots I am aiming for are 5 to 8mm deep no active cooling ,only a squirt of WD 40.What depth of cut should be looking at each pass? My mill is a Sieg X2.7 so it's getting towards the size of an X3.
Thank you.
Thank you.
