arnoldb said:a libation of Namibia's finest should add to the mollifying effect.
Three in fact Arnold.
Just get back on the horse........
Finished the the distributor axles.
![eb6anulus.jpg](https://proxy.imagearchive.com/2fa/2fa1c4e83dcf73c41f1b15c9ba3949cf.jpg)
Top left - drilling the ports & M3 mounting holes.
Then stand the RT upright without removing the part to retain angular alignment - a PITB as you have two parts to do but definately the safest way.
Top right drilling the port cross hole.
Bottom left machining the annulus groove 120° either side.
Bottom right - plan ahead. I have done this before where after meticulously clocking up the work etc. you then find you can't gain access with the cutter - lesson learned.
The finished axle(s).
![eb6shaftb.jpg](https://proxy.imagearchive.com/bcb/bcbecd96595ff2f7619d06b6921c88c3.jpg)
Trial assembly of the cylinders - its starting to look like an elbow engine.
![eb6triala.jpg](https://proxy.imagearchive.com/147/14761f1043da3912351b810e6a82c66c.jpg)
So far so good now for the stiffener bracket.
For some reason I've been putting off the "production run" of 12 pistons, 12 elbow axles, 12 elbow shoulders and 6 elbow assemblies - likely to get monotonous.
I've got an ER collet chuck on order which will help - should arive Thursday so I'll probably do the pistons over the weekend.
Ken
