- Aug 25, 2007
- 3,890
- 715
Here's a video of a simple technique for cutting the spokes in a flywheel. I developed the G-Code to cut the pattern for one space between spokes. After making one pass for one space, the g-code stops and I manually rotate the rotary table 1/6th turn. Then I run the g-code again to make one pass on the second wedge. This is repeated until all 6 spaces have one pass. I could complete the flywheel by repeating the 6 sections with the z-axis lowered. By doing this enough times, I would cut all six sections free.
However, I will modify the g-code to loop so I can make multiple passes on one section until it is cut thru. Then I'll manually move the rotary table 1/6th turn and repeat the g-code loop. After 6 times, I'll have all the sections cut through.
[ame]https://www.youtube.com/watch?v=iDAtJ_oH8dk[/ame]
The advantage of this method is the g-code is extremely simple and doesn't require CAM. The original wedge shape was laid out in Visio.
