Got an answer from Bernzomatic on the output of the 8250-series torches:
Actually, they replaced the original answer which was this:
"Thank you for your question! If you’re currently using propane, which has a maximum burn temperature of 3,600°F, you might consider switching to MAP-Pro fuel. MAP-Pro burns slightly hotter, reaching a peak temperature of 3,730°F, which offers a modest increase in heat."
When I checked the "No" button under "Helpful?" yesterday morning, they replaced the response with the actual answer to the question just now.
