Its all good fun if you don't weaken
Yes, Brian, he (me) is also building this engine, LOL.Very nice build. Someone else on the forum (who will remain nameless) is building that same engine, and I am sure he will enjoy looking over your build.---Brian
That looks very pretty indeed. I hope I can do half as well on the Peewee. (actually 1/2 as good x twice as large = roughy the same, on average )
Hi Mike,
Was suppose to cut cam using same method but I chickened out. The Milling method wasn't any better but after 1/2 dozen bad cams,I got good cams and the Nemett-Lynx Engine fired up and ran well.
Hi Mike.
True .Was faster on the mill,turning RT/cam by 1 degree advance and feed quill by the thou. Problems appeared. RT was reworked/redone/fine tuned before first good cam appeared. Also had to DIY a DRO using M.I.C. Digital Caliper which also had to be reworked and fine tuned to move quill feed by the thou. Was a bit stressed by the unforgiving requirement by the designer--Malcom Steed. His engine really humbled me. The reward was the Nemett-Lynx Engine ran very well beyond my expectation.
