How is yours going Simon?
Hi Ethan,
Mine is going great, though I'm unable to do any screw-cutting just yet.(more on this when I start an unboxing thread, though I suggest you remove your chip guard and inspect the leadscrew carefully)
I've stripped it down, checked it all over, cleaned it up and reassembled.
The feel of this lathe and the finish on turned items is way above that of a 7x14, I should have upgraded much sooner!
I have already finished one project, which is a backing plate to adapt my ER32 collet chuck onto the C4 spindle, this was a nice easy job that was a lot of fun while getting used to the feel of the new lathe. I will also cover this in the unboxing thread.
You are right, this lathe has some grunt!!
I accidentally discovered a small problem with the lock on the Power Feed lever when I was tuning a small 2 or 3mm chamfer on the backing plate.
I moved my hand to pick up a brush and lightly bumped the lever which knocked it into feed for the saddle and away she went!!
Now, I had the saddle clamp locked up tight and I was unable to move the saddle manually, but the power feed sure got it moving no problem!
The side face of the CCGT carbide insert was plunged into the work. (the top-slide was set over for doing the chamfer)
The swarf coming off was about 6mm (1/4") wide and it didn't even sound like was struggling!! (remember, the saddle lock clamp was TIGHT)
After that little misshap and a quick clean-up of the work, my plan of a nice little 2 to 3mm chamfer became a 10mm chamfer! haha.
Post-mortem I discovered that my locking mechanism isn't as per the Sieg part drawing.
Instead of having three locking slots, mine only has two.
The slot that locks the cross feed(3 in the drawing attached) is fine, but slots 2(disengaged) and 1(cross feed) are one slot, there is no metal between them which means the lever doesn't need to be pushed in before rotating.... danger.
So that's my very next project, I will be making a replacement, pronto! Don't want any more accidental power feeds!!
Keep the 7x14 put a shelf up you just never no when you may need it,as for room you got a lot more then me
Thanks TCW, I'm holding on to it for now.
