Pappy Frank
- Oct 31, 2011
- 6
- 0
I have two lathes, one is a South Bend that was made in 1928 and originally was a 16 inch swing. Someone put 2 inch riser blocks on it and it now swings 20 inches. It runs on a flat belt and a cone type step pulley and I have rigged a motor on it with an intermediate shaft so I can get the RPM down to 40. Top speed for it is about 600. I use it a lot but hardly ever over 200 rpm. I wish it could go slower. When I get the back gear replaced, and put it on its slowest speed, I have never done the math, but it will be very very slow.
My second lathe is a 14 X 36 and it is a modern lathe and its slow speed is 70 and top speed is 1200. I use the 70 rpm a lot, and seldom go over 360 rpm. When I do, I have only once gone over 800 rpm in the 6 years I have had it. I wish it could go slower at times, but I have never had need for a faster speed. I could easily still use it if the top speed were in the range you are talking about.
One thing to consider is that large lathes usually mean larger diameters, and when you get larger diameters it means slower speeds. So sometimes the need for slow speeds is a good thing. You can turn a small diameter part at slow speeds, but you cannot turn a large diameter part at fast speeds.
If the price is good, I would encourage you to grab it up. If you do not like it, you can sell it later.
I had no real need for my large lathe when I got it, but about two weeks ago I needed to have my flywheel from my pickup reground, and I was able to set it up and do it myself, saving me a lot of money.
Pappy Frank
Pappy Frank
