Hi Ownthesky2010
Good rationale for using a sidevalve design indeed. I would not expect power output near that of a similar sized two stroke but certainly close-ish to a slightly smaller capacity four stroke.
The 750cc Harley sidevalves raced in America up to 1969 against 500cc OHV bikes and performance was neck-and-neck.
The BSA Goldstar 500cc OHV was considered to have the highest hp per litre for any naturally aspirated pushrod engine developed.
But it could not beat the 750 sidevalve Harleys.
So perhaps you could expect a 15cc sidevalve model engine in good tune to give similar power, or a little more, as a 10cc OHV.
Tben the AMA changed the rules and 750 OHVs were allowed to race so the sidevalve racer's days were over. and the Triumph/BSA 750 four strokes took over.
But, then along came the Yamaha 350 two-strokes and beat them all!! So a 15cc sidevalve model engine might have similar power to a 6cc two stroke????
Nevertheless, there is a lot that can be done with sidevalves. They dont have to be tractor engines. Take a look here
http://www.beautyofspeed.com/workshop/motor.htm
and here
http://victorylibrary.com/main_menu.htm
for a wealth of information on squeezing the most out of this simple, reliable design..
The main secret is gas flow both in the ports and through the combustion chamber. It is always trying to find the right balance between opening up the combustion chamber for gas flow versus compression ratio. Harley found the best way was to forget about compression and focus on flow. Hence 5 or 6 to one. But that is on pump gasoline, not model aeroplane fuel!
Another thing they do is to run a "pop up" piston that sticks up above the top of the bore at TDC by quite a bit. This allows a higher combustion chamber roof which allows good gas flow from the valves to bore, but the piston at TDC "pops up" and fills that space, thereby increasing compression to what it would be with a normal flat top piston and flat combustion chamber.
As a bit of a Flathead "nut", I look forward to your multicylinder projects. Please keep us posted.
