Kpar
Kpar
Hi all, I'm about to have a go at heat shrinking a brass ring onto a cast iron wheel. I need some advice before I start.
Brass ring is 5.5325 ID x 6.4300 OD x 1.3265 Wide.
Two questions,
1. what diameter should I machine the cast, 004" - 005" larger than then the ID of the brass ring?
2. what temp and heat source to expand the brass ring, will oven temp be enough ?
Thanks for any input
Kpar
Two questions,
Kpar
