Well, there's a Jet 9x20 (we all know what they look like. An Elgin split bed turret lathe that I plan on using for a small wood lathe. IMO most wood lathes spindles are POS. Then I have my "project" lathe. A PM 1027 that I am going to modify substancially. New spindle with integral 5C collets, reversing dog clutch system, quick retract on the compound, electronically variable feeds and a number of other things. Right now the headstock is off and the rest of the lathe tore down for moving. A Hardinge or Monarch it ain't but then I don't think I could get a 10EE in the basement
The Elgin on moving day
The "project" lathe prior to removing the spindle
Hi Picked this Link on a browse through "Show us you lathe" An old thread for sure. Looking at the picture of Your 10 x 27 project lathe it looks to be identical to mine. I got stuck into modifying it and have had a lot of satisfaction doing it. now to bore you with the mods done.
Motor replaced with "Baldor 1 H.P D C with Variable Speed Kb Electronic Controler KBCCR at 180 volt dc
Poly Vee belt drive with motor mounted under the bed
Recirculating Oil Pump with Filter feeding to fabricated oil gallery in the gear box lid (Perspex 2 Sheets with galley milled into Lower one and drilled to spray oil to all bearings and gears screwed and glued together)
Runs very quietly and smoothly. No chattering Single Phase Motor and flood lubrication a vast improvement.
Rev Counter (Bicycle Computer Programmed to 167 cm circumference) Magnet Trip on lathe spindle will read to 3000 RPM
QCTP and Toolholders
Ball bearing cross slide and top slide. All jib adjusting screws with 3 mm ball bearing at the end of screw to push on jib
Makes for a smooth operation
Cam Lock Tailstock. All hand wheels balanced
Lead screw with Variable speed drive from Gearhead DC motor 10 mm a minute to 55 mm minute advance or driven from spindle for screw cutting.
Stop yawning I am finished for now
