Admiral_dk
- Jul 15, 2010
- 165
- 0
Hi John
I'm almost 100% sure it's a serial RS232 port (the pins used and the pin 6 to 8 jumper is a dead giveaway), so for gods sake DO NOT connect it to a Parallel Port, because there's a chance that you'll fry the PC in the process !!!!
And for the same reason, be careful, but not paranoid - just take care. The RS232 Port is reasonably protected in it self (unlike the Parallel Port).
All older PCs got a Com Port that's an RS232 port - the really old ones used a 25 pin and the never ones use a 9 pin connector. If you computer doesn't have one - get a USB to RS232 adapter.
The best you can do is to trace the original manual for it - remember : Google is your friend !
If Googling the machine itself doesn't help you, try to Google the controller - it's rather unlikely that there's no manufactor / brandname + model printed somewhere on the PCB.
If this isn't a success, we'll take the next steps together.
The 4 power resistors are there so it's possible to run the circuit on a higher voltage than the motor in it self can, while getting a higher max speed from the higher voltage.
Best wishes.
Per
Best wishes.
Per
