I have a fog buster type system on my lathe and
mill
mill
I like the art work on your walls. Banksey would be impressed.
Hopefully the big clock is for decoration and doesn't actually work. I enjoy my shop more when there is no display of time.
Good idea re the vice. Will look onto that.Looks good. Re your vice, see if you can get some 65mm SHS and create a receiver like a towbar and mount your vice to a 50mm SHS that slides into the receiver. Hold it there with a towbar mounting pin. That way, you can remove the vice and get it right out of the way when required. That was the best advice I received when I built my welding table.
Also rather than waste time drilling a whole heap of holes, why don't you just drill and tap them as required? eg. When you need to mount something, worry about it then.
Yeah, that heavy top was a challenge. You need some form of crane or mechanical lifting machine. It would have been really challenging if my neighbour hadn’t offered me use of his workshop and tools.Thanks Joco for the pics.
I would love a nice table like that. Been meaning to make one but putting it off because of the difficulty of working with the heavy table top!!
What is a 65mm SHS?
quote { if my neighbour hadn’t offered me use of his workshop and tools.} sounds like you have a nice neighbour..
That is one nice table. I just got a 1/2 inch steel plate here in the USA and it was not cheep.
Interesting. I take it that’s just to stop the bbs from to sticking? I have been using antispatter weld spray. It seems to be working well. Also the light rust is also helping in preventing spatter from sticking.Over the years, welding splatter will attach to your table top. If you consider the clamps as the negative electrodes then you could place a sacrificial sheet of aluminium foil between the work and the table. Just a thought for your consideration.
