Bret, now that is a good idea, I am partial to a bit of Stilton.
The work now starts. The time has arrived to get my finger out and get it done, planned time, about a fortnight if all goes well. I am having to rely on other people so timescales can get lost.
So here is the primer, just to see what is to be done in the first stages.
This is part of my rear garden, it contains my shop. I have moved the bench base where it is easy to move around for when the machines come. I put Bandit's bed under it, and he seems happy enough now he has found his old place in the world.
Outside access is thru the metal door at the end of the shop, when the exercise is finished, it will be locked up from the inside and access will only be thru the shop. But if something nasty were to happen, I will be able to use this door as an escape route.
If you notice the large bushes at the back, that is where most of the wooden finger engine came from. I hate the chap that lives there with a vengance. I will tell you a story sometime, about when a gang of us took down a 30ft tree in his garden while he was at work.
This is a closer picture of the entrance door. If you notice at the right hand side of the door, there is a gate. This gives access, thru a narrow opening onto a concreted area behind the shop, and I think I will be putting a small plastic storage shed in there, so not everything has to be disposed of.
This now shows the problem I am up against, all this has to be removed before anything can be done. It is layers deep with tools, motors, metal and WHY. A typical garden storage shed.
If you look at the top of the ic, there is a red circle. I was putting the ladders back the other day and accidently hit the cement board roof, duly causing a nasty open crack. When I purchased the bits to make the shop, I ensured that a few spare panels came with it, as you do. So this can be repaired in about an hour, by unbolting the offending part, sliding the old out and new in, drill and rebolt.
X marks the spot. This is where the new sliding door will be, hopefully self closing by putting a slight angle on the support runners.
I also have a fairly large storage area above the workshop ceiling, there is all sorts stored up there at the moment, but it offers a way out for lighter items to disappear into there.
So everything starts in earnest this evening, when it cools down a bit. It must be touching 70 deg F at the moment, a bit too warm just yet. I have got the yolk out for the wife, she can do all the heavy stuff, it really makes me sweat watching her struggling.
Bogs
