- Mar 1, 2010
- 866
- 82
It's time for another boiler now that my last engine is finished. http://www.homemodelenginemachinist.com/index.php?topic=9412.0
Its a marine engine so needs a marine boiler. I've done a vertical boiler so this next one has to be horizontal. I've recently been reading K N Harris "Model Boilers and Boilermaking" and it has examples of a Scotch Marine boiler and the Inglis variant. The trouble is the plans require something like 6" tube. I've got 3" tube so it's going to be that.
The plan is to fire it with LPG gas (propane/butane) and a through flue burner much like SandyC's plans for 3.5" burner http://www.homemodelenginemachinist.com/index.php?action=tpmod;dl=item175 however the burner flue is going to be 1" tube as I'm only using a 3" main tube. So the first thing was to try out a burner design and see if it would work enclosed in a length of pipe. First attempt was a non starter. I based it on a small Sievert burner which worked well when poked up the pipe. But my copy was a disaster and flashed back as soon as you looked at it.
Next was something based on this old torch that was lying in the junk box. It has a #10 jet which will do fine
So I set about copying the parts. Which is basically a hole for the gas to come though and mix with the air.
All the parts just push fit together for now
Then light it up. It needed a bit of adjusting of the size of the second set of air holes but it fired OK just by lighting the end of the tube. To allow for a bit of tuning I have already made an adjusting sleeve for the air flow ready for some bigger air holes and hopefully to deal with the "pulse jet" noises it makes when the gas is turned up.
[ame=http://www.youtube.com/watch?v=LIvCLxzY0I4]http://www.youtube.com/watch?v=LIvCLxzY0I4[/ame]
There may be an issue with flashback when it all gets a bit hot but successful enough for now to proceed with the boiler design............
