mklotz
Can anyone recommend a source for scale hex head screws corresponding to certain common numbered screws?
Let me explain more clearly what I'm talking about. The table below shows (column CC) the desired AF dimension (1.5 times major diameter) for numbered screws. Column DD shows what's available from virtually all the sources I've managed to locate (Small Parts, etc.). As can be seen, the easily available hex heads for #4, #6 and #10 are just too big. The differences, while small in an absolute sense, are very apparent on small models.
For a few screws, it's possible to make your own or file down commercial ones but for models with lots of screws it's just too tedious and time consuming.
Code:
AA = screw number
BB = major diameter
CC = desirable scale dimension across flats (1.5 * BB)
DD = commonly available across flats dimension
AA BB CC DD
2 .086 .129 .125
3 .099 .149 ?
4 .112 .168 .188
5 .125 .188 .188
6 .138 .207 .250
8 .164 .246 .250
10 .190 .285 .313
