joe d said:
Hi
Can any of the Gurus here tell me if it possible to save video files from U-Tube to ones PC? (And if you tell me that it is possible, be so kind as to tell me how! {Imprecise question... :
Thanks, Joe
Joe
I use a slightly different approach to saving U-Tube files. I use a program called "ZTreeWin". This is a utility program that will
search, sort, find, rename and a lot more. When you view a video on U-Tube it leaves a file called "video[1].flv" in the
"Temporary Internet Files" folder.
I watch the video, then I click on "ZTreeWin" and log my "C" drive.
next I sort the files in reverse order by date. Now scroll down to the first file called "video[1].flv" and rename and copy or
move this file to a directory of your choice. Be sure to keep the same extension name. Now you have a saved copy of the video file with a meaningful name.
To download ZTreeWin go to
http://www.ztree.com/html/download.htm and download the version that best suits your setup. Also you can choose between a self executable file or a zipped file. It is very easy to install and there is a help file included with it that is available when you press "F1" for Help. This is a shareware program that is free for 30 days. Between this program and its predecessor which was called XTreeGold I have used this program for 20 years and is the first program I load on the computer after windows is installed on the computer.
If anyone has any questions on this please ask and I will try to answer.
Don
