Rupnow I. C.Vertical
So here it is my version of Brian's I. C. Vertical, I tend to move at a glacial pace but I did get it done I had very little difficulty getting it to run but it does not run as well as I would like I have to adjust the throttle and needle valve to find a "sweet" spot. I broke down and bought a Traxxes carb for it but that was worse. I will have to tinker with the timing and see if I can improve the problem. Video is courtesy of my lovely wife Buttercup.
frankie
https://youtu.be/9ajj54WhJx0
Frankie,
That looks good. And you built the saw to give it work today.
Congratulations on a good build and thanjk you for posting,
--ShopShoe
There are no drawings for the saw I kind of made it up as I went along. Thanks for having a look and a big thank you to Brian Rupnow his drawings are always a joy to use.
jfw
That's really great! The saw is a great addition and looks like it works perfectly. :thumbup:
