Tin Falcon said:welcome to the board. have not built one get but have a full size plan set from Rudy.
several here have done similar engines.
Tin
Your engine doesn't run because it has air leaks or suffers from friction in the moving parts. The feel by hand doesn't tell you much, the engine sees something it does not like. A good place to start is to remove the power piston and blow some compressed air at low pressure into the cyl. so the leaks present themselves but I don't know what plans you worked from and you may be unable to get a blow-off nozzle over the power cylinder.MarioM said:............Actually I just finished the engine, but it does not look alive at all, it fills OK when run it by hand but no kickback.......I think it has leaks.......any ideas??
This is the first stirling I made and and was a bit anxious to finish it. I will now try to find where the leaks are and see what happens. Thank you for your advise.Longboy said:Your engine doesn't run because it has air leaks or suffers from friction in the moving parts. The feel by hand doesn't tell you much, the engine sees something it does not like. A good place to start is to remove the power piston and blow some compressed air at low pressure into the cyl. so the leaks present themselves but I don't know what plans you worked from and you may be unable to get a blow-off nozzle over the power cylinder.
maverick said:Wecome MarioM,
I have built 2 compressed air engines from Rudy's plans and find the plans to be
accurate and easy to follow. Good luck on the Stirling.
Mike
Hi Tin, I found the engine I am building in you tube. Do you know of anybody who built this engine??Tin Falcon said:welcome to the board. have not built one get but have a full size plan set from Rudy.
Tin
Stan said:I don't remember what plans I used, but I built a Stirling that looks like the one in the video.
Sealing air leaks was the solution to get it to run. I made the displacer guide/bushing several times before I achieved a close enough fit. The hot air has to move from the displacer cylinder through the doss drilled hole to the power cylinder. Any leakage around the displacer piston rod will keep it from running.
My other problem was I used stainless steel for the hot end and SS has poor heat conduction. The second hot end was made from brass. That is not ideal but it works.
I use an alcohol lamp under the hot end and it takes quite a while to get hot enough to run, but then runs well. If I am in a hurry to show it to someone, I preheat it with a propane torch and then use the alcohol lamp.
lazylathe said:Hi,
I have plans for a similar engine.
It is from the Home Shop Machinist Volume 23 November/December 2005.
I think it is called "Brassy Babe" though not sure...
The article is just called " Building a Horizontal Stirling Engine"
The magazine, volume and months above are correct.
I do know it is a horizontal Stirling engine.
Will have a look when i get home although it looks to be exactly the same as the one in the video.
Andrew
Hi Andrew,
You are right. The plans are in the volume you mentioned. I have read it many times and it has been a good source of information. The engine is very similar to the one I built, but it is more refined, a bit more elaborated, a few differences, uses ball bearings and the measurements are different (piston and displacer are bigger).
Mario
Do you remember when you built yours how you sealed the displacer piston assembly.
