Rotary motion to reversible linear motion
I spent a goodly portion of the day modelling all of the components into position and developing wooden bracketry (pale green), pulleys (yellow), and drive belts (black). I also received my package of 50 rubber o-rings from McMaster Carr. Right now I'm rooting thru all my metal supplies to see if I have enough material to make all the pulleys from.
YES!!!---I've got enough material to build all of my pulleys for this project. This afternoon I installed one of my new 1/4" cross section rubber o-rings on my driven shaft, and the results are less than stellar. This is probably because I am using solid bronze or brass pillow blocks on the driven shaft, and I may have to make new pillow block bearings that actually hold ball bearings to avoid the friction I am getting. Fortunately I have a couple of 5/16" ball bearings that I have recovered from an old project.
Today I made up the first of my many pulleys, this one fitting on the engine. I make the grooves the same width as the o-ring that I am using for drive belts. I made up a 1/16"wide knurling wheel a few years ago, and I use it to knurl the bottom of the o-ring slot so that the pulleys don't slip when driving the o-ring. I would have liked to use timing belt style pulleys and belts for this job, but they cost way too much. The last time I bought a timing belt and two small (about 2" dia.) pulleys, it cost me more than $150 dollars.
Just call me the "Pulley King" of Carson Road. All my pulleys are finished except for the output from the clutch. One on the engine, two on the gear reducer and the input pulley for the clutch. I've used up every scrap of aluminum round stock that I had. I actually found a scrap of aluminum plate to make the last pulley from, but I'm too tuckered to do anymore today. I'm amazed that I've made up all of these pulleys from short pieces of stock I found laying around my shop.
Yeah!!! All of the pulleys are finished.--And best thing of all, I didn't have to buy any material. There isn't a scrap of round aluminum left anywhere in my shop, but the pulleys are finished. The engine, clutch, and gear reducer are "posed" for the picture---Those are not the right o-rings shown, but they are in the correct relationship to everything.
I found something out today that I never knew. There are some situations where I would like to use a ball bearing on a shaft, but the outer diameter of a ball bearing is too large for my application. I have always been under the impression that needle bearings which come with the outer race but no inner race must use a purchased inner race, (which again makes the outside diameter too large) or else they must run on a hardened shaft to keep from galling the shaft material. I spoke with a rep for Koyo bearings today, and they make a needle bearing with an outer race that needs no inner race nor a hardened shaft. The rollers run directly on a 1045 steel shaft that is not hardened and they will not gall it. I will go over to Canadian Bearings on Monday and find out more about this. If it's really true, it will get me out of a bind. The outer diameter of a 3/8" ball bearing is 0.875". The outer diameter of a 3/8" needle bearing is 9/16". This is a B68 Koyo bearing.
I foresee lots of woodwork in the very near future. Today was buying wood, cutting to size, and laying out screw holes. I still don't have the wood I need for the risers between the top and bottom plates, but I will check my own stash this afternoon and buy a piece if I need to. I don't mind working with wood---don't do a lot of it and when I do, it's mostly sander and tablesaw work.
Good to know. Amazon has them for $5.85- unfortunately us dollars and don't know if Amazon services Canada
A B68 is nothing special as needle bearings go. It is a full compliment type caged bearing which equates to higher loads. A extremely common bearing.
Here is the Koyo catalog. Look at section 5.1 for specifications on shaft requirements. This includes the "B" series as listed in the first part of the catalog.
A shaft hardness of HRC 58 is recommended as well as preferred steel alloys. http://nocinternational.com/pdfs/koyo-b2003e-en.pdfn
The housing the bearing presses into can be mild steel or even aluminum as long as it meets roundness requirements.
The info the "rep" for Koyo gave your contradicts their published specs. No doubt Canadian Bearings will confirm this for you. You being a engineer can also interpret the specs yourself as well.
(One of my first jobs out of school was for a large bearing distributor. I went to torrington factory school as well as others. Not much has changed)
Not quite sure about the info contradicting things. If you look on page 12 of the manual in the bottom right corner there is a graph showing how to apply a correction factor for load if the hardness of a shaft on which the rollers are running is less than HRC60. It may be that the sort of forces applied to these bearings in model engines is relatively low and so it would be quite OK to use them directly on a non hardened shaft?
I wouldn't disagree. In that chart the coefficient is very near zero for hardness HRC10-15 which is where 1045 would be. To put it another way, you would be in uncharted territory. It might be good enough for a model engine but certainly not what the manufacturer intended. It is a model engine, what sort of life expectancy does it really need?
Again, there is nothing special about a B68 bearing, its shaft requirements are about the same as any needle bearing.
I was designing High Voltage circuit breakers (typically 400kV) in the 1980s.
Some specifications for service life were of the order of tens or hundreds of cycles. I was always "off-the-graph" for "normal" manufacturing suppliers, who were normally making components (e.g. bearings!) for Millions of cycles. So, as with many models, I had to "cheat" and make a best guess of the hyperbolic function from the manufacture's "curve" to the limit strength (point of failure at 1 cycle) on the log-log graph paper.
This worked for some things, but as everything was tested against the spec., I learned that my extrapolations were really only a starting point for fatigue failures, life prediction, etc.
Another case of "by guess and by God!". In this case, God (Faith, Hope and Charity) is "Hope".
But the simple and effective solution was usually "1 size bigger". That rarely failed.
Or just get a smaller OD ball bearing, you can get 3/8" ID x 5/8" OD and put it on whatever shaft you like. Added bonus is they are quite narrow so won't stick out the sides of a piece of plate used as you do for model crankcases like a 1/2" long needle roller bearing would.
https://simplybearings.co.uk/shop/p...l-Bearing-3/8x5/8x5/32-inch/product_info.html
I'm goin to tell you a story, it's sad but true---and it doesn't have a thing to do with Sue---Yesterday I spent the day making things for my friends old Atlas lathe. The wooden frame for my project was all glued up and waiting for me to do a finish sanding and than a varnishing. I had saved money on the base and used a nice clean 9" wide pine board for the very bottom piece instead of using 3/4" plywood like I generally do.---it looked great. And---I bumped it---and it fell on the floor. And split that damned pine board full length into two pieces Today I went up to the lumberyard and bought half a sheet of 3/4" plywood, and used part of it for a new base. I'll do my finish sanding and varnishing tomorrow!!!
I guess that if you had "reassembled" the pine plank with glue it would have likely split again just a small distance from the original split.
"Dead tree material" has a very variable nature and reliability in Engineering terms. - Which is why the Ancients used "Huge sections" compared to modern design calculations.
And I bet that base board didn't need calculations!
I have 120-year old doors. - Excellent wood - that have shrunk with age so much the door latch (>1/2" projection) doesn't reach the catch plate! 1 yard door width has shrunk over 1/2" in 120 years. - That is 1/72th - or 1.4% shrinkage = 1.2% per century. So not a stable material... OK for chairs, but not draught-free doors that stay closed.
I have to make new strikers that are 1/2" longer (Brass), when I get around to it... - Removing the door lock (hidden fixings!) then dismantling the rivetted iron casing to get at the innards will be a bit of a job..
I attempted to order my o-ring drive belts from Global o-ring in Toronto, but found that they have been bought out by on o-ring company in Niagara Falls---so---I ordered them from the company in Niagara Falls and they should be here this week. The wooden base has been reworked to have a plywood base, and it has been stained and the machinery bolted to it. I'm not totally happy with the way motion is transferred from the steel pressure plate to the final drive shaft via the rubber o-ring, so am making up a couple of compression spring holders to hold compression springs against the final driveshaft bearings to hold a more constant pressure between the rubber o-ring and the steel pressure plate.----Brian
