Renovating a Sanderson Beam Engine
BillWalton
New Member
I bought a Sanderson Beam engine from the UK a few months back. I plane to keep the restoration as close to the original as possible. I need to re-mount the stone work and don't know what "cement" to use.
I would leave it the way it is.
Kind of adds some realism to it.
I wonder if thin-set tile cement would do well. It is very 'squish-able" so you could apply it and mash your broken part back into place.
Chris
I'd use epoxy cement for the large fragment and make a "dirty plaster" to smear into the cracks between segments.
A very small amt. of graphite powder from a pencil may tone down the white color of the plaster.
Good thing about using plaster is you can make a loose mix and can wash off excess even from the textured surface of the tiles.
