Mystery steam engine
I still got the centers from tunring the crank on it
I match them to the valve eccentirics
And voila. Regards chris
    2.4 MB
    2 MB
can you take a piece of wire and see if the openings at the ends of the round HP valve chest (1) are linked to the ones at the ends of the LP chest. (2)
If they are linked then that is how the exhaust steam from the HP cylinder gets to the LP chest via cored in passages around the side of the LP chest. It's a bit of a long route but would have acted as a bit of a reciever.
Hi jason and green twin
Its in inches now
Regards chris
Most of those shots with the wire are as I would have expected. It is what links the round piston valve chamber to the slide valve chamber that would be good to know. You might have to poke it in from either end and just get an idea of where it is going as the wire may not bend all the way round. Then measurements can be taken to sort out what needs to be made.
hi jason and green twin
Its in inches now
Chris
Its in inches now
    1.5 MB
Getting there now.
Still not sure what the top and bottom slots of the five do on the slide valve. maybe hold the engine on end and pour a liquid down one and see if it comes out anywhere. Could just be a run out recess for the cutter if you were machining with a shaper
We will also need the diameter and vertical position of the round holes in the round piston valve hole.
Can you put a pair of digi callipers on a fe wof the round shafts as that will give a good indication as to whether the engine was built in imperial as your current sizes don't correspond well with common fractional sizes.
Yes inside admission on the piston valve and the image sin post #127 show a passage at the bottom as well as the previously shown top one so no need to have exhaust pass through the middle of the piston valve which makes life easier.
Getting there now.
Hi jason
I havent got digi calippers bud i will buy
Im sorry i grew up in switzerland and fully in
Metric
I got the chest also
Metric is fine for me too and what I generally work in, though I can cope with imperial.
A couple of measurements with the metric mic will be fine to give an idea of what was used when it was built eg if a shaft is 12.7mm or 6.35mm they are actually 1/2" and 1/4"
Yes they seem odd not what you would usually expect. For example the 0.728" hole you would expect to be very close to 0.750" or 3/4" if imperial. Or 19mm if metric
The port face is elevated up, so that the valve can over-run the ends of the face, and also to get the valve rod in the right position relative to the eccentric, without having to use a lot of bend in the rod.
The image below has an elevated port face, and it appear as if there are passages at either end, but they lead to the bottom of the steam chest.
It looks like your port face adheres to the typical 1X,1X,2X,1X,1X layout, with landings for over-run on each end.
This is a very typical port layout for a steam engine with a D-valve.
Port length was typically 70-80% of the cylinder bore.
But the sizes Chris measured do not 5, 4.1, 10, 5.9, 6
Going to need to tie it down a bit before deciding on the valve sizes.
