Hi there John!!
Thank you so much for the compliment, not just a compliment but what I consider a very inspiring commend.
I am currently working on the gear pin and realized I dont have the 5/16 x 24tpi die nut. On inquiry I could have one supplied at around 50usd and had to wait a week for it. I then decided to cut the thread with the lathe. Then I had another disappointment. The gear setup on the lathe requires a 70 teeth gear and that specific one is not amongst the set of gear. I have ordered that also which will take 2 weeks to arrive. In my anxiety to move forward with the part I came across a set of dies and taps on eBay for 40usd which will also arrive in about 2 weeks. This means I am going to put this part aside to complete later. What is really difficult for me is to build engines in imperial as where South Africa is Metric. One can just not find the right tools here. Eg reaming with a 5/16 reamer is required a lot on this engine where I have to use a boring bar all the time to reach the correct hole size.
I started lest night on the bush for the gear on the same gear pin and did the boring bar thing again as per above. As I was about to polish the bush and part it our electricity went off again.
I will post few photos later.
Thanks again!
