It did. And it did!
She has arrived and I pretty much converted the necessary parts of my X2 to this Solid Column.
A couple notes on this:
1.) Dang, the thing is way more sturdy than the X2 column. Its just beefier.
2.) I followed pretty much what this guy did:
http://robertsprojects.blogspot.com/2013/04/mini-mill-solid-column-conversion.html to convert my X2 over to this Solid Column. All went pretty well except for the below:
3.) I put the Air Spring conversion for the X2 (
https://littlemachineshop.com/products/product_view.php?ProductID=2258&category= ) on this Solid Column kit... I tried the recommendation on the 4th post at this link for where to put the air spring hole on the back of the column:
http://www.homemodelenginemachinist.com/showthread.php?t=6416&page=3 DO NOT FOLLOW THIS. It is just false. This method put my hole at about the 12 inch mark on the back of the column. However, the directions right from LMS with the air spring say to put the hole 15 inches down. My first hole (done by following the link) came out not allowing the head of the mill to go down even close to where it should be at the lower limit. The 15 inch hole that LMS recommended was correct and I have full motion now with the air spring. The reason I didn't go with the LMS directions at first for this hole is because I wasn't sure if this Solid Column kit was a different dimension than the X2 column... But alas, it was.. what did one guy call it? Mindless hand wringing here...
Stick with the 15 inch recommendation from LMS on this for that Air Spring hole in the column...
4.) I was out .004 on my X axis tram right away when I tested it... I have another thread going here on this:
http://www.homemodelenginemachinist.com/showthread.php?t=23631. The interesting note here on this is: I first put in a .002 shim on the base to column mating surface (half the distance I was out of tram) and this left me with a .002 difference still on my next tram test. I went up to the .004 shim and I am dead on now with my tram. I did this out to the ends of the table and then took the tram so my sweep only went the length of the column (so like 4 inches between tram points) and I was spot on here as well. So, methinks the whole idea of putting in a shim half the size of the amount you are out of tram is a complete falsity to be honest... The tramming method I used was this one:
http://www.machinistblog.com/how-i-tram-my-mini-mill/. But, what I did is take a 3/4" rod, put a 1/2" hole in it, and put a 1/2" x 8" cross bar in that hole to hold my dial indictor. I locked this bar down with a set screw like from the link. I tried with the cross bar the guy had in this article and the thing just moved too much in the whole system and I did not like this in the least. So, this bracket I made instead with a fixed 1/2" rod is kick arse - my Dial Indicator is fixtured basically to the end of the 1/2" rod and makes a very nice tramming bracket... There is literally 0 movement in the tramming bracket as a whole and gives the accuracy I was looking for.
5.) **A possible concern I still have is that the whole reason I went with this solid column kit is because of all the not favorable stuff I read about the column not being rigid on the X2's swivel base. I had read guys being out on their Y tram .003 - .006 right out the box with the X2 column. And hence, you see all these column firming mods going on and whatnot to remedy this... Well... The funny thing is I did a quick Y tram (Pitch) test last night on this new Solid Column setup and it looks like I am out .003 on this dawg as well out the box (and yes, I did the spindle to column tramming as well before all this and the differences there were negligible and I didn't make any adjustments). On that little X2 table that's .003 over like 2 inches on the Y side of things... So, into head scratching mode I went again... I can push my finger on that column and can move it as well like guys report with the X2 column so not real sure. I am going to throw an appropriate shim in on the Y side of things, 0 it all out, and crash into these AR15 80% lowers very, very soon. But, it still looks like there could be flex with this setup too unfortunately... Will it matter for an AR15 80% lower? Most likely not from what I have read...
That's where life stands with me on this mill at the present time!
Thanks for all the replies!
